Installing some LS6 valve springs and have a few questions.
motor is a stock cam LS1
My first question is do i need to change the seats at all? i was reading that the ls6 seat is thicker then a ls1 seat by .015, when i bought the ls6 springs i did not get the seats with them, as i was told originally that they are a direct drop in.
second question is has any one ever noticed if the LS6 springs do indeed give you a few more usable RPMs? what i mean by this is right now my LS1 pretty much hits a air wall ( valve float i think ) around 6200, so thats where i shift, but i need to run 4th out to 6500 threw the traps so my thinking was that the LS6 springs might move that air wall up a little and i wondered if any one every tested this and took note of the max RPM difference between the springs on a stock LS1 cam? any data and help would be great i am swapping the springs in a few days, thanks guys.
the installed height of the LS6 with a stock seat should be fine. it would only truly become an issue if you were worried about the coil bind. it might have a few pounds less seat pressure with the difference in thickness. i highly doubt it would matter.
thanks for the speedy replys, now maybe some one who can tell me if there is a rpm difference or not, the motor is turbo charged so i think the pressure behind the valve isnt helping much with float either. and its only 4th that will have to rev out, the factory limiter is moved to 6800 and i have the lingenfelter lnc-003 so i can set the spark limiter where ever i need to once i see where it ends up trapping at.
obviously with a higher seat pressures the control of the valvetrain will be better. your experiencing less valve float on the top thus more power ay a highr RPM. pushrod deflection will be less but i am surprised the cam even makes power above 6000 to be honest since 99 and later cams were smaller then the 97-98's. have you tried short shifting it? it might result in a faster ET but less MPH by keeping it in its optimal powerband. just my randomn thoughts here.
garygnu as stated its all stock, its only a little 500-550 whp set up, pump gas ect. the stock push rods are supposed to be the same as the LS6 ones and guys have ran super chargers and turbos on stock LS6 and LS1s with no problems at low boost, i might look into some hardened push rods but i already bought these springs and am going to run them
Hi,
Yes they are a direct install but the difference is in the valve seals.
LS1 springs use valve seals without the hat while the LS6 springs use valves seals with the hat.
the springs dont care what valve seal you use, the newer ls6 style have the seat and seal as one unit, on my car the seat and seal are separate its this seat that is slightly different in height. I did end up getting the comp cam push rods and valve seals and installed the springs last night. the new comp cam seals are all viton and there is no difference between the exhaust and intake seal, i think perhaps my valve seals had been changed at some point in the past as they was all also the same no brown and black as i expected.
