HEAD Opinion plz help needed
hi all
i wanna install new heads to my A4 T/A were i want the highest compression ratio i can get cause i want my car to be DD and i just bought new fast 92mm with nick wiliam 92 mm and a wet NOS system with a 150 shots ,, when i installed the new fast to try it i didnt get a good resault cause i havent got enough compression and the flow wasnt that good i was told to get a 66cc 205 head atleast to get good power ,, so what do u suggest guys ?
appreciate any feedback
Stock heads are 66cc combustion chambers. If you want higher compression ratio, you'll need smaller chambers like at least 64cc which should give you about 10.5:1 CR. A ported pair of 243 heads should do the trick. If you can afford it, Trick Flow CNC 215 or AFR 205 heads would be even better.
