changing oil pump
changing oil pump
just curious its just bolt off and on right i wan t to replace it cause i heard 97-00 LS oil pumps are known no go out or should i leave it how it is
LS1Tech Premium Sponsor
Yes, it basically just a swap in and out, but you need to be very careful reinstalling it and replace the pick-up tube o-ring. It is not uncommon for people to roll or pinch the o-ring when reinstalling and then you end up with very poor oil pressure.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
