5.7 aliminum block sleaves 408ci
I have 5.7 block aliminum I wouls like to maje it 408 By using sleaves How much power i can get from this block ? Power What about the boost issue Will i be limited with boost on my f1c ( 18- 20 psi ) ? If i used the sleaves will that be danger when i reach +800 rwhp
Another question. Ls2 block is 6.0 which is can go to 402 by changing the crank 5.7 with sleaves 402. What. Is the diffent Are they same ? Or not.
Thanks
navy
Thanks
navy
TT-TECH Veteran
A 5.7 block can be sleaved with darton sleaves and you can make it a 427 if you like and you shouldn't be limited by the block as far as HP. There are a number of different blocks GM made yeah they made Iron and aluminum 6.0's and now 6.2L's. 6.0 have a 4" bore and the 5.7's had a 3.898 both had 3.622 stroke crank the later ones have 58 tooth reluctors and the earliers a 24. That is a quick run down hope that helps.
i have heard of allot of horror stories when it comes to re sleeveing the ls1 block.
i would just grab an ls2 block and make a 408 from there
do not use diesel sleeves, if you do decide to re sleeve the motor, use sleeves that where designed for the engine and make sure you get somebody that knows what they are doing to do the work.
A Darton MID sleeved LS1 block is a very strong and expensive option. You must install wet sleeves in a LS1 block where you have option of wet or dry sleeves in LS2/3/7 blocks. The MID series are a great design but need to be carefully installed.
Plan to drop about $3K for the sleeves to be put in. That does not count line boring or other machine work to finish up block. Probably should also get billet caps installed while you are pouring money in.
If you are really planning on running 20 psi - my suggestion would be an iron block for a whole lot less money. LSX would be another option and still be cheaper than sleeved LS1.
The $3000 was for a Darton MID sleeve job - does ERL use Darton sleeves for $2600? 4.125 bore?
Chevrolet LS1 with the ERL SUPERDECK Ι system and Darton sleeves.
This particular LS1 has 427 cubic inches of displacement with a bore of 4.125” and a stroke of 4”.
http://erlperformance.com/images/sto...icpriceweb.pdf
http://erlperformance.com/superdeck-i-4-bolt
all post say go to Darton sleeves ,whan i go to Darton sleeves 4.125 bore with f1c i cant see 18 or 20 psi only 14 or 13 psi so 18 psi on 408cid same 14 psi 428cid (800 to 850 rwhp ).
Try going to ERL website. I really dont understand all the posting of misinformation and question in this thread that are easily answered in the ERL website? See quote from website below.
Im sure ERL knows what they are doing and are using proper sleeves. I dont get why people dont just call and ask or email about the product if they are so interested instead of taking a shot in the dark guess or saying something that only carries some truth within it.
OP, with that much boost, id go with the 4'' bore block. Save the hassle and do it right.
No, we do not use the MID sleeves. Our sleeves that we machine in house are the same ductile iron but we machine them for our specific application that has been engineered for these applications. Our Superdeck I has been proven time and time again and to my knowledge I don't know of anyone that has pushed a stock sleeved block harder and longer than the Ohio Boys have with our Superdeck I blocks. I would welcome any of you to pm Mike or Steve with the Ohio Boys to hear about it first hand. We are always improving our product and looking at ways to increase the quality, strength and reliability of our blocks. Please let me know if I can answer any questions you all might have in regards to our product and services and I would be happy to help. Thanks!
