98 Ls1 Valve Seals
Old 02-28-2010, 10:25 AM
Ls1Mx-5's Avatar
Default 98 Ls1 Valve Seals
Hi, I'm rebuilding a stock 98' Ls1 with the '806' heads. What valve seals should I order? Thanks
Old 02-28-2010, 11:16 AM
vettenuts's Avatar
I would just use the GM parts. They work very well. SDPC can get them for you.
Old 02-28-2010, 11:50 AM
Ls1Mx-5's Avatar
Thanks thats a good Idea, I'll just go to my local GM parts department.
Old 03-01-2010, 02:37 AM
nauticalstar2012's Avatar
Id make sure and get the updates valve stem seal when you go to the gm dealership...in 98 they used a different seal then 2000+ . The revised version has the seat and sel in one unit as the 98 comes in 2 different pices and is a little more of a pain to install IMO
