Stock 98 LS1 heads
Old 03-02-2010, 01:27 PM
91 LS1 Z28's Avatar
Default Stock 98 LS1 heads
I had to pull the heads off my car because I manually over revved it and bent some valves. Do I have to buy new head bolts ? I am guessing I have to but which bolts do I need since the bolts covered by the intake are different then the center bolts in the heads and head bolts near the headers ? Also does anyone know what they get torqued to and the sequence you torque them in ? Thanks for any help.
Old 03-02-2010, 01:41 PM
Bizzles's Avatar
Yes there are 3 diff. head bolt sizes. Just buy a set from like summit, should be around $40. Do not re-use the head bolts as they are torqued to yield (means they are no good now that you took them out). Don't re-use the gaskets either lol. Then go to auto zone and Haynes manual, it has the torque specs & sequence as well as a bunch of other day to day ls1 howtos.
Old 03-02-2010, 01:49 PM
Z28SteveA4's Avatar
yea thats a big no no to use the stock bolts once the stock ones are torqued down they stretch so u have to buy new ones. like said above dont use the old gaskets. Hey since u have the heads off u might as well but atleast ls6 heads on and a nice cam LOL
Old 03-02-2010, 03:05 PM
SOMbitch's Avatar
http://www.ls1howto.com/index.php?article=3
Old 03-02-2010, 04:11 PM
Justus67's Avatar
ARP makes re-usable head studs, but they are not cheap. Normally $300+. But if you want a very reliable stud and plan on pulling the heads at a later date they are the way to go.
Old 03-02-2010, 04:16 PM
garygnu's Avatar
LS1howto.com
Quick Reply: Stock 98 LS1 heads
