6liter question
Old 03-02-2010, 06:58 PM
layz's Avatar
Default 6liter question
i got a 6.0 block and was wondering if any of my ls1 out of my 2000 camaro will fit on the 6.0 block...and if so what would i need to get..i am wanting to get it running for now and do a cam swap later...will my tranny 4l60e fit on the 6.0.....basically what will i need to get it running...
Old 03-02-2010, 07:24 PM
TransAm Mania's Avatar
Everything should fit. On my 6.0 L I have mostly LS1 parts. All the front accesories, oil pan, 6 speed trans, intake, fuel rails, injectors, are all LS1 style. The heads are interchangeable also. Trans bolt pattern is the same on all LSX blocks.
Old 03-02-2010, 10:06 PM
tspence45's Avatar
Everything's physically the same about the blocks, except for bore size. You'll also have to drill and tap a hole for the LS1 alternator bracket to work on the 6.0.
Old 03-03-2010, 09:39 AM
jason00ss's Avatar
you can even use your stock crank if you want to, just get new bearings and clean it up at a minimum
Old 03-03-2010, 12:06 PM
Justus67's Avatar
If you don't feel secure about tapping the hole for the alternator, have the machine shop do it. If its off or angled its sucks a lot. But other than that everything is virtually the same. I'm doing the dame build right now at the house.
