cam & spring combo?
cam & spring combo?
my cams lifts are 614/627 will the spring specs below be a good match??
Designed for moderate Hi Performance Hydraulic Roller Cam applications up to .640" lift.
Made of super clean Chrome Silicone OVATE wire for long life.
Spring Specs:
* 1.290"/.885" OD
* 1.055/.650" ID
* 130 Lbs @ 1.800" -Valve Closed, Spring Installed Height
* 320 Lbs @ .600" lift (1.200")
* 345 @ .640" Lift (1.160")
* Max lift- .640"
* Rate- 313 Lbs
* Average Coil Bind @ 1.090"
* Higher Pressures then Comp 26915 Springs
Retainer Specs:
* 1.030" OD
* .640" Inner Step
* Thickness from top to bottom- .336"
* 7 Degree
* Great for high lift cams
* Black Oxide Finish
* For LS series engines w/ 8mm stem valves
* Not for 11/32" valves on SBC or Vortec
Spring Specs:
* 1.290"/.885" OD
* 1.055/.650" ID
* Max lift- .640"
* Rate- 313 Lbs
Retainer Specs:
* 1.030" OD
* .640" Inner Step
* 7 Degree
LOL math fail indeed! i hate math, however, im gonna wait to change my screen name until i have my car running. i only had it for 2 days until it broke and my 2jz never failed me so im gonna wait to actually get to drive the car before i decide which is greater than which....
1 Post
awfully tight on spec for lift. luckily coil bind isn't supposed to happen for a bit more. make sure and check each one w/a height gauge mic when installing. don't be afraid of spring shims, but don't go wild with them.
