98 camaro centerbolt valve covers
hi I have a 98 camaro ls1 im doing an overhaul on and the heads im buying accepts the centerbolt valve covers. I was just curious to what kind I can put on there that will fit without clearance issues.
If you are using the stock LS valvetrain, then the stock center bolt valve covers will work just fine, I have only ever heard of clearance issues with some aftermarket roller rockers and jesel rocker systems. When I did my swap I just purchased some centerbolt valve covers from a member here and was good to go.. Can find them from 20-50 bucks for sale.
