3000 to spend. wat sould i buy?
Old 03-08-2010, 11:50 AM
gmc04's Avatar
Default 3000 to spend. wat sould i buy?
I have about 3 grand to spend. I already have air intake programer zex kut and bolra exhast. Wwhat sould i buy? I want to make the mosr power i can.
Old 03-08-2010, 06:40 PM
fatmat80's Avatar
need some more info on your combo like m6 or auto? and what is a "zex kut" ?
m6:
wet kit(n20), and a tsp heads and stg 1 ls6/ms3),3.90 or 4.10 gear
auto:cam/head(prc
3600 stall, 3.73 gears and same heads and cam
just my .02
Old 03-08-2010, 06:45 PM
Johns00Z28's Avatar
Yeah definitely need more info about your setup. Also don't forget about your rear end and trans (if your an auto) that need upgrading the more hp you're making.
Old 03-08-2010, 07:13 PM
David Q's Avatar
Mild cam, converter, and a good tune.
Old 03-08-2010, 08:20 PM
gmc04's Avatar
I have a zex nitrous kit. Borla exhaust.k&n intake. Diablo programmer. Every thing elses is stock. I got3.42 gears
Old 03-08-2010, 08:22 PM
gmc04's Avatar
Auto trans
Old 03-08-2010, 08:24 PM
ssfast99's Avatar
again more info lol. daily driver? horsepower/torque now? rpm range? straight line car or corner carver? what year and model is the car unless i missed that?
Old 03-08-2010, 08:25 PM
jester ls1's Avatar
CAM!! 92 92 and headers!
Old 03-08-2010, 08:27 PM
ssfast99's Avatar
Originally Posted by jester ls1
CAM!! 92 92 and heads!
why waste his money on 92/92 setup? waste of money!
Old 03-08-2010, 08:29 PM
jester ls1's Avatar
Cam 92 92 headers = 80 Horse power!
Old 03-08-2010, 08:32 PM
KevinR's Avatar
This^^^^
ssfast99's Avatar
lol cam= 400
cam swap parts= 500
92/92 = 1200
headers = 700
80 horsepower = 3000
OR
t-rex cam = 90 rear wheel for me with ls6 intake lol. 92/92 is not necessary. but if you like spending money then go for it. just think money can be placed somewhere else to be faster. being faster doesnt always take more horsepower.
Old 03-08-2010, 08:37 PM
jester ls1's Avatar
lol cam= 400
cam swap parts= 500
92/92 = 1200
headers = 700
OR
90 HP out of the t-rex damn! When does the power start?
Old 03-08-2010, 08:41 PM
KevinR's Avatar
I was wondering the same thing. Plus the cam swap part=$500. You get some REALLY good deals
Old 03-08-2010, 08:47 PM
edwardzracing's Avatar
You can have all the power in the world, but that weak *** 10 bolt that's putting all the power to the ground is only going to last so long.
https://ls1tech.com/forums/gears-axl...-new-pics.html
There's your solution, for under $3000 depending on what you want to do. Just keep that link above in mind after you drop 3 grand on making the car faster and end up with a toasted 10 bolt and have to scratch your head when you don't have 3 grand anymore to buy a better rear end. LOL. Whatever you choose, good luck. That's a pretty good amount of coin... spend it wisely
Old 03-08-2010, 08:53 PM
jester ls1's Avatar
Ya this is the best advise I can not belive my 10 bolt has not broke yet. This is the next step for me, but I will brake it first before I replace with the above package. Thank you for the link Edwardzracing!
Old 03-09-2010, 01:11 AM
You bet man. It just seems to make sense. I was in a similar situation as the OP, and thought to myself, "Hey, I'll piece together a little budget build that makes more power than what I have now and speed this pig Camaro of mine up." I started piecing things together and then suddenly realized the final link to all this power I wanted to make. That final link... a weak *** 7.5" 10 bolt rear end. Before long I was picturing myself getting half way through the race season and destroying the 10 bolt. Then having to wait for who knows how long in order to save up $2000+ for an aftermarket rear end... even complete used ones are in this range. So to hell with the idea of building more power. Now, with a bad *** rear end, near invincible, I can build hellacious power down the road and never have to worry about a 10 bolt staying together when the 3500 pound car leaves at 4000+ RPM on stickies. Glad I could help. Give Eric a call and he'll be happy to help you out. When it comes to customer service, he's tough to beat.
Old 03-09-2010, 01:16 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I would do a full suspension first including the rearend if I had it to do all over again for a 3rd time. And dump that programmer and get a real tune. All you are gonna do with that thing is lean your motor out and need to use that 3k$ just to get it started again.
Old 03-09-2010, 08:47 AM
gmc04's Avatar
Who sould i go to for the tune?
Old 03-09-2010, 10:36 AM
NC98Z's Avatar
Where are you located?
