LS6 crank.. what rods?
I just picked up a new LS6 crank, and thought they had floating rods/pistons. When I reference the part number it shows it uses press fit pistons.
Any thoughts?
Any thoughts?
Here's the strange thing; when I reference the part numbers with a LS6 crank, the part number shows a press fit piston pin, but the rod number references to a floating pin LS2 rod?????????????
I'm trying to figure out what rod/piston assembly I should use, as the 2 combo are different weights. I'm building a budget Fe LS2 (LQ9).
