What lifters and rocker arms to run??
I got a bolt on ls1 and im bout to pull the motor out port the heads put a ms3 cam wit springs and rods! And im also gonna do lifters and rocker arms!!
I have heard a lot of good and bad about the cts-v lifters and wanted more opinions and other suggestions??? And also bout rocker arms??
Help me out guys!! Thanks
I run Morels and stock rocker arms with the HS upgrade my motor goes to 7200. The stock rocker arms are a solid design and offer lightweight and strength and on a GM head work awesome.
Once again i appreciate all the suggestions and will keep them all in mind!!
Now im also thinkin bout putting on the bottle!! Any better specifics wit the bottle on it????
definately upgrade the rockers, I have the comp kit, 135$ not that hard to install, no more worrys about the stock needle bearings ending up in my oil pan,,,, as far as lifters go, I paid 500 for my morels, its a hard bullet to bite, but you will never have to worry about it anymore.
My latest H/C is using new stock LS1/LS6 lifters I bought from Gaterman products the ran me $100. The rockers I am using are new stock rockers with the trunnion upgrade. You can look at my sig and see how it all is working together. By the way the custom cam I am running has close specs in lobe separation to the MS4 and has a 614 lift in and out on a 112 LSA. If you want info where to get the stuff PM me and Ill give it to you.
https://ls1tech.com/forums/generatio...-question.html
I ended up running mine at .040"
hopefully this will help, i had the same question here recently.
