Reassembly questions LS6
Old 03-13-2010, 10:51 AM
blazer427X3's Avatar
Default Reassembly questions LS6
A few quick questions before I start putting this engine back together
Is it true that head bolts should not be re-used ?
Do I need to replace the o-rings on my BBK intake even though they look fine and the intake wasn't leaking ?
A friend mixed my lifters up (compcams roller lifters). Do I need to replace them all now ?
If I can re-use the lifters do I need to resoak them in oil before the install ?
Thanks
Old 03-13-2010, 11:14 AM
Darkman's Avatar
Thanks
The head bolts should NOT be reused.
O-rings are cheap but the risk associated with the reuse is small.
I would replace the lifters. Reinstalling them in the wrong place will cause new wear but more importantly pulling the heads just to replace a bad lifter is a lot of work compared to the price of new parts.
Old 03-13-2010, 11:25 AM
conan's Avatar
X2
Do not reuse GM OEM head bolts or crank pully bolt, they are tourque to yeild bolts.
I would replace the intake "O" ring gaskets, I reused mine in the past and have had vacume leaks. So now I spend the $25 for some new felpro gaskets. I'd rather spend $25 then pull the intake twice per job.
http://www.speedinc.com/cont.cfm?cid=C0000723
The lifters are 50/50 in my book, I agree with "darkman" it could cause more wear but probly not much. Either way I would soak them in oil (new or your old ones)
Old 03-13-2010, 11:27 AM
...with cheese.
Armageddon's Avatar
Head bolts are Torque to Yield, they should be replaced.
Intake O-Rings will be fine, I reuse mine.
Roller lifters can be reused in different holes.
I've soaked them and I've let them pump up on their own, both worked fine.
Old 03-13-2010, 12:35 PM
Darkman, Conan, Armageddon ...
Thanks !
