View Poll Results: which heads
prc 2.5 5.3
8
42.11%
prc 2.5 ls6
11
57.89%
Voters: 19. You may not vote on this poll
(TSP COME IN) trying to choose a set of heads for my Torquer v.3 cam
Old 03-15-2010, 06:11 PM
WALK NASTY984's Avatar
Default (TSP COME IN) trying to choose a set of heads for my Torquer v.3 cam
want to either pick up some prc 2.5 5.3 heads or some prc 2.5 ls6 heads from texas speed....just dont know which heads would offer the best performance with my cam any suggestions would be GREATLY appreciated
Old 03-15-2010, 08:02 PM
TXZ28LS1's Avatar
id opt for the PRC 2.5 LS6!!
Old 03-15-2010, 08:03 PM
any specific reason why you pick the 2.5 ls6?
Old 03-15-2010, 08:04 PM
jester ls1's Avatar
PRC 5.3!! These heads made 50 RWHP & 40 RWTQ!!
Old 03-15-2010, 08:07 PM
dang jester very impressive numbers!!!
Old 03-15-2010, 08:12 PM
jester ls1's Avatar
LS1 heads suck big time. You will not lose low end torque with these 5.3 heads and they are only $1100.00 for the pair its a no brainer!
Old 03-15-2010, 08:13 PM
do you mill you heads down any?
Old 03-15-2010, 08:22 PM
jester ls1's Avatar
No, just order the Texas Speed 5.3 heads and (do not use after market rocker arms) just do the trunion up-grade $130.00! 50 HP!
Old 03-15-2010, 09:11 PM
fatmat80's Avatar
From what i have seen Ls6s are better..Have yet to see a race or a dyno session that would prove otherwise..And if you are after compression they can be milled as well..just my .o2
Old 03-15-2010, 09:23 PM
David Q's Avatar
My car runs great for a TSP budget build. I bought the 5.3 heads, for 1100.00 you can't go wrong.
Old 03-15-2010, 09:25 PM
TXZ28LS1's Avatar
TSP definitely has good options for bang for the buck.
Old 03-15-2010, 09:32 PM
supernova1972's Avatar
Better is subjective and application specific. I plan to use stg2.5 5.3s and a 228r or Torquer v.2 for my DD build. The 5.3s will bring your compression up a tad and aid in low end grunt more than LS6 heads.
Old 03-15-2010, 11:39 PM
MUSTANGBRKR02's Avatar
The LS6's can be milled to achieve compression bump. the LS6 is a better flowing head stock. I have not seen flow sheets for these two side by side.
Old 03-16-2010, 12:49 AM
racerfox's Avatar
PRC 215!!!!!!!!!!!!!
i have that setup i made 453 rwhp with that cam and heads
Old 03-16-2010, 09:48 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Between these two options I'd go for the Stage 2.5 LS6 heads. The only real advantage the 5.3L heads have is they are less expensive. The LS6's typically make a few more hp/ftlbs all the way from idle to redline over the 5.3's. Keep in mind the chamber on the 5.3's are CNC'd so they are about 63cc or so out of the box. The LS6's are not CNC'd chambers, and start at about 64cc. So the arguement for compression is basically out the window as well, since we mill any of our heads at no extra charge when you purchase them new!
Let me know if I can help
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 03-16-2010, 11:57 AM
Jason 98 TA's Avatar
The PRC Stage 2.5 LS6 heads are pretty hard to beat for the money. In a ideal world where $$ wasn't a concern I'd run the PRC 227 aftermarket castings, but if we're on a budget the PRC Stage 2.5 LS6 heads are hard to beat!
Let us know if we can help & make sure you tell the guys what camshaft your running so we can mill the heads accordingly.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 03-16-2010, 02:34 PM
TooLateVTEC's Avatar
The LS6's came on a Z06 and the 5.3's came on a truck engine, no competition.
Old 03-16-2010, 03:26 PM
98hardtopSS's Avatar
I am in the same boat.I would like one of these heads to go with my futral cam 228/588.
I am undecided as well. I hear so much good stuff about the 2.5 5.3 heads. But for some reason I still like the thought of LS6 heads....Cant beat the bang for buck though.
Old 03-16-2010, 06:09 PM
thanks everyone for all the replies and suggestions....just really trying to do my homework before i break down and buy anything...just dont want to make a $1500 mistake if you know what i mean
