6.0L swap, bolt on parts
Will all of my LS1 externals fit the 6.0L block? Alt, PS Pump, A/C, water pump, etc......?
What should I keep from the 6.0L and from the 5.7L?
Yes, externally the blocks are the same. The main caps from the 6L should be all that you need to keep. Everything else will transfer from you 5.7 to the 6.0....except your pistons of course.
Good luck.
Good luck.
