Why is my engine ticking
Old 03-19-2010, 01:51 AM
-DLS-'s Avatar
Default Why is my engine ticking
My engine started ticking when I fucked up a shift.
I took off the valve covers and everything looks fine. No cracked springs, rocker bearings are fine, nothing is loose.
Should the next thing I look for are bent push rods?
Or am I just poking around in the wrong area right now?
I don't think it's a knocking sound, so Im looking around at top end wise.
Old 03-19-2010, 02:30 AM
blue98Z's Avatar
Yeah I'd pull the push rods and check them and go from there. While you have them out you can thoroughly inspect your rockers to make sure you didnt knock any needle bearings out also.
Old 03-19-2010, 06:40 AM
AFASTYZFR1's Avatar
Check the pushrods!
It could also be an exhaust leak but if you over revved motor and it just started ticking I would lean towards a bent pushrod
Old 03-19-2010, 06:57 AM
jgoo's Avatar
I vote pushrod
Old 03-19-2010, 07:09 AM
tdevil55's Avatar
Pushrod all the way..
Old 03-19-2010, 07:43 AM
pauls99z28's Avatar
Pushrods! now its time for upgrades. and since you gonna check rockers might want to check in on them trunion upgrades too.
