5.3 needs new heads.opinions wanted
guy i have a '05 silverado with a 5.3.
found out i have a cracked head.now im looking at aftermarket heads.called summit and was told about a gm performance ls2 head complete for under $500. each(assembled)
64cc
2.00in/1.55ex valves
since im swapping heads why not a cam and intake?
what parts will work good on a 5.3 in a truck? (heads,cam,intake)
its a 2wd crewcab so i want to keep my torque level up but more hp would be a blessing.
this is the first time i've had to open up a ls motor.
64cc
this is the listing on the gmperformance heads:
P/N 12576063
LS2 Cylinder Head Assembly
Lower cost alternative to the LS6 head
Fits any 1997'2008 LS family engine*
2.00 Solid stem intake, and 1.55 solid stem exhaust valves
.570 max valve lift
210cc 'cathedral port' intake ports
70cc D-shaped exhaust ports
65cc combustion chambers
Bare head P/N 12564825 available separately
Upgrade the valves to LS6 hollow stem valves with P/N 17801930
also the ls hot cam caught my eye:
88958733
LS Hot Cam
I: 219 E: 228
(1.7 rocker) I: 525 E: 525
112 Same cam as in kit P/N 12480033
P/N 12576063
.570 max valve lift
88958733
LS Hot Cam
I: 219 E: 228
