Need some help setting up the timing set
I'm helping my friend GTODave do his h/c swap in his GTO and i wanted to ask you guys about what you think of this:
I just got the timing set put in place and am about to torque the cam bolts to spec, but i spun the engine over 360* to make sure timing looked good.
It appears to me that its 1 tooth off but wanted to ask you guys before i start putting everything together again
Here's a picture I snapped really quick to put up on here:
Thanks,
Andrew
Thanks,
Andrew
Ok cool, thanks guys.
I'm going to have to take the timing set off again anyways, kinda realized i only snugged down the plate that holds the cam in place. so i need to take the set back off, i'm going to use a paint marker and mark the timing gear and chain to make it going back together easy again
Thanks guys,
Andrew
Thanks guys,
Andrew
