TEA 1.5s with X1 PtoV clearance?
Wanting to run this cam with these heads milled .015 for 11.1. Friend of mine is putting together a motor with these heads milled .010 for straightness with the TR230 and he had only .020 clearance. He siad .060 to.080 is optimum. Ive been told I can run this cam with these heads by several people including TEA. Is anyone running a cam like this? What are your heads milled? Any clearance issues? What is you clearance if you ckecked it? I have other 2 buddies running PP5.3s with the X1 and TR230 and no diasters yet and they havent checked clearance. Any info will be Appreciated. Jason
LSX Mechanic
Jason we've already talked about this once
W/ the X1 cam, you can safely mill ~.020-.025. If you're going to run a 5.3L head w/ .010-.015 you'll have about 10 feet of clearance in there. FYI I am running a bigger cam than the X1 with .025 off my heads and no flycutting...
Josh
Josh
