Polishing crankshaft journals
Old 03-24-2010, 08:54 PM
98goldta2's Avatar
Default Polishing crankshaft journals
Will polishing the crankshaft journals reduce the clearances enough to require the use of oversize rather then standard size bearings ?
Old 03-24-2010, 09:06 PM
KCS
Moderator
KCS's Avatar
If you're talking .010" oversize, forget about it. For about .001", you can, but it's not a good idea. It takes FOREVER and the journals wouldn't be nearly as straight and round as it would be if a professional ground them.
AES Racing's Avatar
if done properly no
Old 03-25-2010, 04:25 PM
98goldta2's Avatar
I plan on having a shop do the polishing. just needed to know what size bearings to order to put it back together. crankshaft journals are all within spec. I did not plan on turning it down .010"
thanks for the advice guys
Old 03-25-2010, 11:49 PM
lmt0705's Avatar
if the crank is in good condition now your machine shop will only take a couple tenths at most. that miniscule difference wont cause a need for oversize bearings
Old 03-26-2010, 06:43 AM
butler's Avatar
Do you mean 10 thousandths?
Old 03-26-2010, 06:57 AM
KCS
Moderator
KCS's Avatar
Oh, I totally misunderstood the question!
I agree with the above, when done correctly, polishing is only going to take of an insignificant amount of material.
Also, a "tenth" is how a machinist refers to .0001".
Old 03-26-2010, 09:34 AM
lmt0705's Avatar
yep, used to be one then gm no longer needed my services
