What is the torque setting for ARP main studs.
I need the specs for the ARP main studs. I lost my instructions and I tried searching but could not find it.
Thanks in advance.
Thanks in advance.
sorry i dont have a scanner to upload the whole page but i have the instructions from mine.
says to screw the studs into the block hand tight only. also lubricate stud threads and nuts with ARP ULTRA-TORQUE FASTNER ASSEMBLY LUBRICANT. Than instal nuts onto studs and tighten them hand tight. than torque them down, and the torque recommendations for the nuts are as follow:
Inner studs- 4.770 long 60FT LBS
Outer studs- 4.550 long 50FT LBS
M8 side bolts- 20FT LBS(use rtv sealent under the head of bolt)
Windage Tray nuts- 28FT LBS
hope this helps
hope this helps
