ms4/afr 205
ms4/afr 205
Im new to this ls stuff and I was hoping to get some opinions on if you guys think this is too much cam for what im trying to do. It's a carb setup and its going to be right at 11:1 with a set of afr 205's. Its already got aftermarket pistons, so piston to valve clearance isn't an issue. The car weighs about 2800 lbs with a 4.10 gear and a th400 trans. I hope this covers everything. Thanks
That should make for a pretty stout combo. I assume you are milling the heads to get to that compression number unless the piston is a dome piston? In that light of a car, and the right converter, the car has potential to put down a number at the track. We have run that combo before with nice results on a couple different cars in the past.
Jon
Jon
