99 5.3 bored to be 5.7 rotating assembly?
Old 04-01-2010, 01:44 PM
brian.harmon1974's Avatar
Default 99 5.3 bored to be 5.7 rotating assembly?
i know that i can bore my iron block 5.3 out to be a 5.7 and ive looked for rotating assembles. but all i come up with are complete forged set ups that cost $3500 and up. anyone know of a cheaper kit? and is there a rebuild kit for a 5.3 or LS1 that comes with all the gaskets and seals i need?
Old 04-04-2010, 11:03 AM
bump!
Old 04-04-2010, 11:29 AM
MUSTANGBRKR02's Avatar
You can reuse the stock LS crank and just go with a set of forged rods and pistons. Through in a set of bearings and you should be around 1500 or so depending on your choices for everything. You can buy a master gasket kit for like 125-150 i think from parts stores or online.
Old 04-04-2010, 11:37 AM
01ssreda4's Avatar
I thought there was a sponser on here that sold a complete iron shortblock 5.3 converted to 5.7 for about $1800. Swanke Engines or something.
Old 04-04-2010, 11:41 AM
01ssreda4's Avatar
http://www.schwankeshortblocks.com/S...rt%20Block.htm
Old 04-05-2010, 05:05 PM
ok thanks, could i just get away with just getting stock replacement pistions and rebalancing the assembly?
Old 04-05-2010, 05:07 PM
and where are you finding the gasket kit? ive looked all over the net and gone to napa with no luck
Old 04-05-2010, 05:11 PM
garygnu's Avatar
WS6 store?
Old 04-05-2010, 07:55 PM
IFRYRCE's Avatar
All these posts and no answer?
The answer is: YES.
You can bore a 5.3L to 3.9 inch bore, but not to 4.0. Technically a factory 5.7 is 3.898 bore, so you are golden. They use the same 3.622 stroke.
4.8 and 5.3l use the same block, so you can do the same thing to a 4.8 too, but it winds up as a 5.2, unless you swap the cranks to the 3.622 crank, then it is a 5.7.
Old 04-07-2010, 09:17 PM
thank you! i knew i could do it i just didnt know the exact specs.
Quick Reply: 99 5.3 bored to be 5.7 rotating assembly?
