cam ?
Old 04-01-2010, 08:46 PM
CMQuickcoupe's Avatar
Default cam ?
ive seen that there r 2 different LS6 cams the first with 520 lift and the later 1 with 550 lift.i see lots of guys useing a LS6 cam in there turbo build and just want to know if everyone is using the bigger 1 or is anybody running good with the smaller 1 or maybe its better to go with a custom turbo cam ? Thanks for any help you can give Chris
Old 04-01-2010, 11:59 PM
brian_rs/ss's Avatar
custom turbo cam for sure. if you are gonna go through the trouble of doing a cam swap then do a cam thats worth doing.
Old 04-02-2010, 11:06 AM
this is going to be a fresh build and putting it in a fox body just trying to put this little project together fairly cheap and make lots of power
