Power under the curve cam
Looking for a cam to make good power under the curve and maintain good street manners. I have an LQ4 6.0L, LS6 intake, A4 with 3200 stall, 3.73 gears and full exhaust. Any ideas?
1st off... DUFFSTER Love the avatar!!!!
2nd... Justus, take a look at my dyno in my sig... I have a 6.0 LQ4 as well. I really like my 224R cam, but if I could do it all over again, I might step it up to at least a 228R or low 230's (I have to watch out for PTV Clrearances with my 59cc heads)... The one I have right now though is ridiculous for street fun...
LS1 Tech Administrator
Try to keep your duration at or under 230 at .050" and your overlap under 7 degrees at .050". There are literally TONS of cams that fall under that.
TR224
TSP 224R
TSP 228R
EPS 226/230
yada, yada
Don't fall into the bigger is better trap. The first NA 10 second LS1 F-bodies ran cams that were 221 and 222 at .050".
TR224
TSP 224R
TSP 228R
EPS 226/230
yada, yada
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
TR224
TSP 224R
TSP 228R
EPS 226/230
yada, yada
TR224
TSP 224R
TSP 228R
EPS 226/230
yada, yada
I was hoping Pat G would have a say. The TR224 was the very first one I looked at. I still have the factory piston and I think they are concave, .011. How much will this affect my end result? Oh, I'm looking for 415-430 on hp and torque and good street manners. Its not my daily driver, but I do drive it every chance I get. It will see the track once almost every month. I want the curve smooth, so it feels like the car is constantly pulling up the front end as I accelerate. I'm an accleration junkie, not top speed.
I ran a tr-224/3200 combo for a while. Its a nicely matched set. I shift at about 6200 and on the dyno that was about when the cam ran out of steam. You dont have to spin this cam high to get your power is my point. With the LQ4 dished pistons, you may consider milling your heads some for a compression bump.
^^^I agree, and I would likely run the 241s, bc to my understanding 241s and 317s are basically the same heads except the 241s have smaller chambers. 241s are like the milled version of 317s.
Building a similar motor for my 89 S10 Blazer LQ9/4L80 trans with Explorer 8.8 with 3.73's. Using the stock heads 317's which are same port design and flow the same as 243's except they have a larger chamber 70cc/64cc for 243's, I believe. I would def use them over the 241's. I'm milling mine .025 which should get my compression close enough to 10.5. Your LQ4 with milled 317 heads will get you somewhere around 10 to 1 or so. The 241's will give you a little higher compression but you would be giving up head flow. I'm staying on what most here consider a small cam matter of fact I'm going to use one of Pats new EPS cams I believe 222/226 it should make plenty of power. Def going to be surprising lots of cars on the street with this setup,Lol.
(6-7 thous. per cc reduction). From what I've read its safe to mill them up to .030.
I'm liking the TR228, but the more I research all these different cams the more I like the sleeper factor. If I pop the hood they will see the stock intake and no nitrous lines, with the right tune on a TR224 or TR228 I could put down over 400 easy on motor. For all they know I have a vaccuum leak!
+1 on the TSP 228R. That looks like my cam, they have a very reasonable package with cam, springs and rods. Thanks for the help everybody! Now if I can just get my flexplate issue worked out I'll be in good shape!
