H/C Questions just a few
Im going to be getting some PP stage II heads pretty soon just wondering if i should get 5.3s or 5.7s, how much do the 5.3s raise compression?
Also too should i get the heads milled as well? if so what length pushrods should i get?
Im also going to match these with a TR 230/224 or the TR 227/224? Anyone have any pros/ cons of either for this combo?
Thanks for the wisdom in advance
Wade
Wade
I would go with the PP 5.3's. I just put them on (see my other thread on the specs) The CR will be 10.7. You should'nt have any P/V issues with those cams. U can use stock length pushrods if I'm not mistaken. Good luck!!
I like PP for the price but open to suggestions/ combo it will be a daily driver but i can handle it if the cam is a little much.
thanks for the quick reply
The TEA 5.3 Stage 1.5's are an excellent alternative and with hand touch ups more potential. The TEA's also make excellent torque. With a customer 224 cam that's very driveable, my set up with the oldest version of TEA head makes 390rwtq at 4,000 rpm. Peak numbers are in sig.
Maybe Damian can comment about his new TEA 1.5's and Futral cam that make a good bit more low end torque than my set up does.
I suggest talking with Brian at TEA before making your final decision on which heads to purchase.
Thanks Black Bird just trying to find a good combo im looking for 410-430 at the wheels. My main reason for PP was price and i have seen many with good numbers with these heads.
Wade
Wade
Call TSP and talk to Jason. I think they have two guys there locally that are making over 440rwhp with the 5.3's and a TSP231/237 cam. They can also fix you up with tuning, either inhouse or via mailorder. They did my tune thru the mail and it has worked out really well. There really isn't that much of a performance difference between the 5.3's and 5.7's. If you are buying, might as well get the 5.3's for a little extra compression, they cost the same money as the 5.7's. Also, I'm pretty sure TSP has a killer "combo" package that gets you the heads, cam, and other must have items for your install for a damn good price.
Thanks gomer,
Locally where in Houston? or DFW?
Ill give Jason a call soon.
Thanks for all the advice everyone.
Hows that Spec Stage III working out gomer?
Wade
Wade
LS1TECH Sponsor
I have an 01 so LS6 intake factory as for tuning i need to find someone good in DFW TX area
Mikey, which heads and cam were used?
