What would this cam be good for
Old 04-09-2010, 08:25 AM
NINE8TA's Avatar
Default What would this cam be good for
OK i got this cam with a short block i bought and the guy didn't know anything about it so after some investigative work and about 30 mins on hold with comp
i found out the cam spec's are 224/230 539/539 114 lsa with 4 degrees advance so what would this cam be good for... nitrous?
Old 04-09-2010, 09:52 AM
SOMbitch's Avatar
It will work pretty well with nitrous or N/A. Will probably make 380 +/- a bit with stock heads....
Old 04-09-2010, 10:15 AM
TooLateVTEC's Avatar
It would be good to run 1.8 rockers on b/c that lift is weak...stock cam lift is .500 haha.
It would run fine NA or spray like ^ said, but not good for forced induction with the 114+4.
Old 04-09-2010, 12:18 PM
tdevil55's Avatar
Well, there are many applications that this can be used for..
1. Table leg replacement
2. Paper weight
3. hammer
4. drilled out and made into a desk ro table lamp(may actualy do this with my stocker )
5. custom stick ball bat
6. cut in half and add a chain, home made nunchucks
7. mount it to a wall, double paper towel roll holder
etc..
Jk, what they said^.
Old 04-09-2010, 02:32 PM
tdevil, you forgot custom room lamp man !
Old 04-09-2010, 04:07 PM
zstripper2k's Avatar
DO you think that would have a decent chop for the sound. Looking for a cam I can use LS6 springs on. Mostly looking for sound and cost savings over power gains.
Old 04-09-2010, 04:11 PM
02*C5's Avatar
If you are looking for sound get a good exhaust.
Old 04-09-2010, 04:44 PM
Already have full exhaust, want a choppy cam sound to add to the soundtrack.
Old 04-10-2010, 07:00 AM
SOMbitch's Avatar
It will have a mild chop but the 114 LSA will hurt ya there.....
Old 04-10-2010, 10:04 AM
davidws6's Avatar
Default Cam
You did not specify WHAT your going to put it in ?
What vehicle and weight. M6 or A4 ? ?
If you don't want it, I'll take it off your hands
Old 04-10-2010, 10:09 AM
thunderstruck507's Avatar
if you want sound might need to go tighter on the lsa
Old 04-10-2010, 10:24 AM
JP
JP's Avatar
yay sound....
