Anybody running the TSP 231/237 with shaved heads?
Old 01-05-2004, 06:58 PM
01pewterls1's Avatar
Default Anybody running the TSP 231/237 with shaved heads?
If so how much?
Old 01-05-2004, 09:00 PM
mike c.'s Avatar
i would also like to know. i want to run a cam like that,i have 30thou off my heads,but i have valve reliefs in my pistons. anyone????
Old 01-06-2004, 08:04 AM
LS1 BU's Avatar
I was told that TSP has run this cam with .010 off the heads. with 1.57 exhaust valves. The told me that my TEA 5.3 lilter 2.02/1.60 with .010 milled, would be very close but should work.
Old 01-06-2004, 12:03 PM
LS1Tech Premium Sponsor
Trevor @ Texas Speed & Perf.'s Avatar
We have seen a customer try .010" milled off of his heads with our 231/237 cam, and it did work. The clearance does get close, and we ALWAYS recommend that customers check their piston-to-valve clearance to verify that they do have adequate clearance with their setup. With a cam as large as our 231/237, we will recommend to not shave the heads. Shaving a set of heads .030" with this cam and stock pistons will certainly not work, but it's a different ballgame if you have valve reliefs.
Let us know if you have any other questions.
Trevor
Texas Speed & Performance
__________________
