T-Rex or custom grind???
Old 04-12-2010, 03:28 AM
BennyB's Avatar
Default T-Rex or custom grind???
Im just looking for opinions here... the car will be cam only and will stay that way for a while, but in the future would like to run some heads and a 100-150 shot of nitrous. Thanks in advance!
Old 04-12-2010, 03:49 AM
lemons12's Avatar
Intentions for car?
Are you going to/do you have....
Spend the money on FAST setup
Have an awesome tuner
4000+ converter
410 or lower gear
spin it 6400+ RPMs
free flowing exhaust
when you get heads, are you going to get heads that can flow enough for that cam
Very few setups "need" a TREX (or similar size) IMO.
Old 04-12-2010, 04:07 AM
BennyB's Avatar
will be shifting at 6400+
4:30 gears
4000 stall
will buy fast 90/90 or similar if need be
open cutouts
and id like to run for heads the trick flow 215s
Old 04-12-2010, 04:09 AM
lemons12's Avatar
4:30 gears
4000 stall
open cutouts
You will be fine running that cam then... If me I would go with a mamofied 102/102 setup.. Just depends on how much you want to spend.. A normal FAST setup would get the job done decently though.
A custom grind will make more power if you know exactly what your setup is going to be... But the TREX has proven itself over and over.
Old 04-12-2010, 04:20 AM
BennyB's Avatar
haha well put and thats why im still debating. I would love to do my own custom grind... but then again the trex has definetly proven itself.
Old 04-12-2010, 04:34 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Just depends on who you ask to spec the cam for you really. Talk to Geoff at EPS. He probably helped on the design if not 100% of it, for the TRex from the get go. Its going to cost the same amount of money, so I would put my $375.00 in the hands of a conscious cam spec'r.
Old 04-12-2010, 05:14 AM
BennyB's Avatar
i was specd a cam by predator z a while back and basically still debating on that custom grind or other and the t-rex. i really want to try a custom grind and see what my dyno numbers will be. I want something nobody else will have.
Old 04-12-2010, 11:35 AM
BennyB's Avatar
i was also wondering what lobe to go with been looking at the xfi or xer lobes
Old 04-12-2010, 08:03 PM
johnster's Avatar
got a trex i will sale
Old 04-12-2010, 08:42 PM
00MaroonZ28's Avatar
Is this car a daily driver? You're gonna hate the 4.30 gears in an auto and it won't make it to the end of the track in 3rd gear without some tall tires. I'd suggest 3.73 if this is a daily driver and at most 4.10's if for the track.
Old 04-12-2010, 08:49 PM
SICKSS/Z28's Avatar
trex is close to the vindicator so i vote trex i wish i would have went trex instead of the vindicator
Old 04-12-2010, 09:00 PM
Nitroused383's Avatar
I'd go with the EPS 236/248 cam on a 110 LSA. Will have more bottom than a trex and rev higher.
Old 04-12-2010, 10:43 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You can't just say that sentence and walk away. Why are you regretting the Vindicator?
Old 04-13-2010, 12:46 AM
'91firebirdformula's Avatar
how about a cam suggestion?
Old 04-13-2010, 12:55 AM
how bout a custom grind for that particular set-up from an expert
Old 04-13-2010, 01:14 AM
lemons12's Avatar
Horrible advice.. If someone doesn't have the ***** to DD a car with a TREX/MS4/Etc along with the supporting bolt ons (410s or lower, 4000 converter or bigger, etc etc etc) then that cam is not for them.
Ever wonder why there are ton of big cam cars out there that get drug by MUCH MUCH smaller cam cars? That is the reason. People put these huge cams in and try to make it street friendly with a 3500 converter/373s/ls6 intake for money purposes/etc etc etc and it just destroys the setup. Where as a bit smaller cam you can go with those things and it is a perfect setup, making it faster.
This is a max effort cam, if you don't want to go max effort then pick another cam.. There is no arguing that.
Old 04-13-2010, 01:27 AM
AznMuscle's Avatar
This is pretty much spot on. That is where I am hurting...no FAST or better flowing exhaust. So I am only trapping 118 with my large 242/248 cam.
Old 04-13-2010, 01:57 AM
BennyB's Avatar
Its not a DD and I run 28's at the track so im fine there... streetability is no issue if you cant tell by the mods i have mentioned already. Some more mods done is about 250-300 lbs taken out of the car, skinnies, no front sway bar, etc.
Old 04-13-2010, 02:20 AM
lemons12's Avatar
You are on the right track for one mean son of a bitch!
I say Trex, ****IF**** you have a good tuner.
Old 04-13-2010, 02:57 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
So you take my quote from that stock heads thread and I will take your quote from this one. Well said!
