Valve Stem seals size???
Old 04-12-2010, 05:53 AM
monster81's Avatar
Default Valve Stem seals size???
im in the process of cleaning up a set of 241s for a LS1 rebuild. need to get some new stem seals,,whats the size of the stock LS1 valve stem seals?
oh yeah, and whats the best way to clean carbon and burned oil build up on valves?
Old 04-12-2010, 06:34 AM
outkast6991's Avatar
not sure how they size the seals but the valve stems are 8mm
Old 04-12-2010, 10:28 AM
synisterC5's Avatar
i have an extra set from clevite/mahle. they are the newer models with the spring base attatched, will work with any beehive spring. i'll let em go real cheap if you want?
Quick Reply: Valve Stem seals size???
