What is going to work with a Torquer V3. PLEASE HELP
Hey guys,
Torquer V3:
231/234 .643"/.598" 111 LSA
I'm rebuilding my motor.. I'm at the halfway mark here. I either need to step forward and get some new heads, or go backwards and take apart my whole block and go with a smaller cam.
I currently have Pro Comp 5.3 heads that were just cleaned up. It's an LS6 block, stock pistons. The guy at the machine shop is telling me there is no way that a Torquer V3 is going to have optimal clearance in my set up.
Are there ANY head setups that will bolt-on out of the box and have the necessary clearance for my motor?
My only other option here seems to be flycutting, and re-using my old heads. Although re-using my old heads will apparently not be the best idea.
So, anyone.. please help.
Thank you
Torquer V3:
Thank you
looking to spend 1200-1600 for heads. That's either a TSP Stage 2.5 5.3 heads or TSP LS6 2.5 heads. I'm thinking the LS6's would bolt right on no problem.
http://texas-speed.com/shop/item.asp...d=134&catid=40
I also wanna know what are the best heads & set up for torquer v3, by nxt year I'll have my motor heads& cammed, my frd used 243 heads on a torquer v3 ran great, but 4 months later he blew the motor, when I take apart my motor I want it to be final so I am also searching on a best set up for torquer v3,
