Z06 cam with 243 heads and no tuning
Hey guys just installed z06 cam and 243 heads on my ws6 with the stock tune idles fine (revs go up and down a bit at idle sometimes) just wondering if I should take it easy until I get I tune? Or is it going to be okay at WOT? Will the maf recalulate the fuel added with the air? Or am I risking engine damage running to lean or rich at WOT
Broke a valve with my stock heads due to crappy 98 push rods so I got a 243 heads already assemabled didn't feel like swapping springs just wanted the car running so I put a cam in that matched the springs, for a shitty cam pulls pretty good higher end I just hope I don't break anything els from stomping on it without a tune
Dyno tune I just been busy at work mybe I'll have time next week to get it done, before the h/c my m6 threw down 306 to the wheels with just long tubes plus I added ls6 manifold while I was doing a swap so I hope to get similair numbers to the ls6's
Your LS1 tune is probably lean at WOT if that's an 02+ cam and 243s, so I'd tune it before getting medieval on that bad boy...
DesertLS1, my T/A and I agree with your calculations...
You can see my bolt-ons and LS1 dyno numbers, and my LS1 was all stock including the intake. I put down 308/324 before tuning.
This is all on a Mustang dyno, so bump my numbers 15-20 to compare them to a generous dyno...
I'm hoping for around 375-380 from the LS6 with all the same bolt-ons.
It can be done. Why is the question. If you save the money for the upgrades save a little more and get it tuned. There are no down sides to getting it tuned. Other than having to pay for it I guess.
I have the complete z06 pkg and I don't have a tune yet but I would like to know what will It do with long tubes I have 04 ls6 cam , heads, intake, udp ,maf ,3.42"s siftkit in tranny ,It run like hell but I never got any #"s on it because I don't have any tires yet , but I wanna put Lt's or some mac mid's on it to boost it up.
