Comp Cams rocker arm trunion upgrade!!!
Old 04-15-2010, 09:42 PM
SweetS10V8's Avatar
Thumbs up Comp Cams rocker arm trunion upgrade!!!
I just got my L92/LS3 rocker arms back from having the crappy trunions replaced with Comps Trunion upgrade kit. No more worrying about needle bearing destroying my engine!!!!
I sent them to Brian at Spectacle Solutions and he pressed them in for me! Here is his install thread...https://ls1tech.com/forums/sponsor-s...m-upgrade.html
Before:
After:
Old 04-15-2010, 10:19 PM
sjsingle1's Avatar
looks nice....may be doing mine SOON
Old 04-17-2010, 02:50 PM
SweetS10V8's Avatar
Bonus!! I thought I might have to buy the shorter rocker arm bolts for the intake since I have CNC heads and typical bolts are said to stick into the runner. The bolts included are just right!
Ill have to see if my old rocker bolts were protruding into my intake port or not.
Old 04-17-2010, 02:57 PM
02*C5's Avatar
Best upgrade I did by far very best. You will be very happy not having to worry about the needles ruining your engine. I spin mine to 6800 and am running a 614 lift on my cam. Shes not a DD but I do run her some times for a week straight at times when I feel the itch. 94K on the clock and still running strong. Love them LS engines dam it.
Old 04-17-2010, 07:45 PM
LS12Fast4U's Avatar
Who did you buy them from?
Old 04-17-2010, 09:28 PM
SweetS10V8's Avatar
I ordered min straight off of Comps site. Its $5 cheaper off of Summit, but these are so popular I wanted them ASAP. So ordering off Comps site made sure I didn't have to wait for them to send them to Summit then wait for Summit to ship them to me. Summit is still backordered on them its says for 9 more days. I have mine delivered and installed already.
http://www.compperformancegroupstore...Category_Code=
Old 04-17-2010, 10:26 PM
bearcatt's Avatar
When I bought the Comp Cams rocker arm trunion upgrade, mine didn't come supplied with the washer that goes in between the bearing and retaining clip.
The Harland Sharp trunion upgrade rocker arms do come with the washer that goes in between the bearing and retaining clip.
The Comp vs Harland looks like the same parts with the exception the washers not being supplied with the Comp kit.
Old 04-17-2010, 10:27 PM
Squirts11's Avatar
So you sent them your stock cores and they send back a set with the upgrade already installed? How much did it run you?
Old 04-17-2010, 10:35 PM
bearcatt's Avatar
The Comps are a do-it-yourself kit.
Harland Sharp setup requires you to send in a set of OEM rockers and now they offer a new do-it-yourself kit.
http://www.harlandsharp.com/conversion%20kit.htm
Either way the Harland Sharp is supplied with the washers.
Old 04-19-2010, 07:28 PM
LS12Fast4U's Avatar
Dont you have to press them in though?
Old 04-19-2010, 07:34 PM
Unaffliated Racing's Avatar
These kits are now back in stock! They are a very hot item and won't last long untill they are out again. Call and place your orders....
$215 shipped back to you.
Thanks,
Brian
901-461-2893
Old 04-19-2010, 07:42 PM
joecar's Avatar
I'm not sure, but it seems to me that you press out the stock trunion, and then the new trunion is held in by a circlip on each end.
Old 04-19-2010, 07:48 PM
joecar's Avatar
Is the Harland Sharp price for doing 16 rockers (Comp's price is for doing 8)...?
edit: Comp's is for 16, I just wasn't able to read.
Old 04-19-2010, 07:56 PM
They are press in. My price is for the kit installed on your rockers. If you want just the Comp kit, it's $140 shipped
Old 04-19-2010, 08:18 PM
bearcatt's Avatar
Yes you do. I have a press.
Old 04-19-2010, 08:20 PM
bearcatt's Avatar
Does the Comp kit come shipped with the small thin retaining washers ?
Old 04-19-2010, 08:59 PM
SweetS10V8's Avatar
Comps price is for all 16!
I bolted everything back up tonight and everything looks great!!!
Thanks again Brian!!!
Old 04-19-2010, 09:01 PM
joecar's Avatar
Ok, I see, press in also, thanks... I have access to a 20 ton press.
Old 04-20-2010, 01:47 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
That should be adequate. lol!
Old 04-20-2010, 01:56 PM
Squirts11's Avatar
What is the added benefit of the flat washer that comes with the Harland Sharp kit?
Quick Reply: Comp Cams rocker arm trunion upgrade!!!
