JWIS or Rollmaster single timing chain
Doing H/C and i dont trust the stocker but i dont want the hassle of a double which is better JWIS or Rollmaster?
Thanks
Thanks
I thought you have to pull the crank gear and install a spacer and that it was a pain the the a$$ to get the oilpump pickup tube back on with everything moved foward?
a double is the way to go.if you're gonna go to the trouble of tearing it down that far might as well do it right.yes you have to pull the crank gear off because you will be putting one on to fit the double and thats no harder then getting the balancer off i thought. the spacers for the pump are kinda thin so its not any harder putting that oil pickup tube bolt in then it would be with a single chain on IMO.
LS1Tech Premium Sponsor
The Rollmaster timing sets are the ones we build all of our engines with. They are excellent quality and are very hard to beat for the price! You can buy a double-roller non-heat-treated set for $74.99 or a heat-treated adjustable with the Torrington bearing for $93.99. The single-roller Rollmasters are currently on back-order, but we have some double-rollers ready to ship.
Let us know if you have any questions.
Trevor
Texas Speed & Performance
Trevor
You don't have to worry about which chain is better... Why? ... Rollmaster don't make any chain.
If you purchase a "Red Label Premium" Rollmaster Timing Set, the timing gears will be made by Rollmaster in Australia, and the chain will be a JWIS chain, made by Iwis Ketten in Germany. If you buy the cheaper "Blue Label Economy" Rollmaster Timing Set, the gears will also be the Rollmaster gears, but the chain will be the cheaper Rolon chain made in India.
Ron,
Ron,
Trevor
Trevor
Well, I have / had a non-adjustable single Rollmaster Timing Set (single keyway) that came with a JWIS chain. Ordered it from KB Engines in Australia for around $68 delivered.
Rollmaster gears and JWIS chain.
Originally Posted by 01PewterWS6
Machine pulley????? Do you mean on an aftermarket ASP pulley or the stocker as well?
Wade
Wade
My single rollmaster that I bought from Trevor (Texas Speed) has the good chain. Just like Tin Indian
