200 shot?
ЯєŧąяĐ Єl¡m¡иąŧøя ™
If you are really planning on n2o being your power adder I would switch from that reverse split cam to a more nitrous friendly traditional split. Bigger exhaust side is gonna be your friend. ESPECIALLY since you want to hit a 200. You are actually running the opposite if what I ran in my nitrous Z28. lol
am no expert BUT from what i have researched 150 is about max for the stock bottom end, 200 you better have a short block laying around.
also like stated before you are going to need a traditional cam, i would not even try to run any type of power adder with a reverse split cam, you are going to bottleneck your exhaust up, you will have a lot of exhaust that will not be able to escape. You will see a drop in hp and your cylinder will retain so much exhaust that something will give eventually specially with a big shot like that if your bottom end doesn't commit suicide first.
