will 5.3 ported heads be to small for a LQ4 build
Old 04-18-2010, 09:24 AM
badmfkr's Avatar
Default will 5.3 ported heads be to small for a LQ4 build
will 5.3 ported heads be to small for a LQ4 build?
Thanks
Old 04-19-2010, 04:19 PM
jmm98LS1's Avatar
I run PRC 5.3 heads on my 370ci. Probably not optimal heads for the combo, but even so it's still making 500rwhp through a 3" steel drive shaft, 9" and 325/50/15's.
Old 04-19-2010, 06:08 PM
djsanchez2's Avatar
^^^ Off the spray? If so details, bro details....
Old 04-20-2010, 03:57 PM
jmm98LS1's Avatar
Yes, on motor. In 1500ft DA I go 124mph n/a at 3900lb race weight, on the jug it goes 135mph on a conservative tune. Whatcha wanna know?
Old 04-20-2010, 04:30 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Is yours going to be stock stroke, or 4"? For a stock stroke, the 5.3's can do the trick and have been proven to make some very nice power!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 04-20-2010, 05:17 PM
john563's Avatar
hmm got those same heads..looks like I'll be reusing them ..Thanks! nice numbers on your 370ci..
To op sorry for the highjack
Old 04-22-2010, 12:46 PM
djsanchez2's Avatar
Motor details: What pistons, rods, cam? Also what trans are you putting this through? If auto what stall? Just curious because i rarely see a 370 do over 500 to the wheel, but they are a site to see when they are done right.
I'll bet you **** off the dude that go big cubes and have to work hard on a bad set-up to break 500whp
Old 04-27-2010, 04:25 PM
jmm98LS1's Avatar
12:1 compression, mahle flat tops w/4cc reliefs, scat 6.125" rods, lightened ls6 crank. Cam is 246/254 .613"/.613" 110+3. It's through a built t56 and spec 3 clutch, 3" strange steel drive shaft, moser 9" w/4.33's 35 spline axles and detroit locker. I'm happy with the motor for what it is. It's a lil soft on torque compared to a 400"+ (only made 450tq), but that's what the nitrous is for.
Old 04-29-2010, 12:45 PM
rich5368's Avatar
Do you run this on pump gas?
Old 04-29-2010, 02:17 PM
jmm98LS1's Avatar
Yes, I run it N/A on pump 91 octane with no problems. Dynamic compression is 8.8:1, quench pad is .040". I do run 110 octane on the jug though.
Old 04-29-2010, 08:46 PM
rich5368's Avatar
Awesome thanks.
Quick Reply: will 5.3 ported heads be to small for a LQ4 build
