Should fly cuts be equal???
Old 04-19-2010, 08:24 PM
MUSTANGBRKR02's Avatar
Default Should fly cuts be equal???
I've never dealt with fly cutting pistons, but while pulling a motor apart i noticed that the fly cuts from piston to piston are noticebly different sizes. I would think this would effect compression and AFR from cylinder to cylinder.
Is this correct?
Old 04-19-2010, 08:34 PM
Bluewire's Avatar
Are you sure it is flycut? or is it valve to piston contact?
Old 04-19-2010, 08:41 PM
The pistons are fly cut they are just noticeably different from piston to piston.
Old 04-19-2010, 08:46 PM
bigboykilroy's Avatar
They should be the same in size if done properly. Post up a pic.
Old 04-19-2010, 08:48 PM
I will have to snap pics tomorrow morning when i yank the engine. I will post up then. I didn't think it looked right but like I said first time dealing with them.
Old 04-19-2010, 10:04 PM
Paint_It_Black's Avatar
Should they be? yes. If they are off a bit from one to the other are you going to notice it as an issue? no. A flycut is only a CC or 2. If you are off by one here and there, you are changing the compression in that cylinder by 1/5th of a point. It will still run fine but it's sloppy work.
