6.0 Cam Help
Old 04-24-2010, 03:45 PM
kmw0481's Avatar
Default 6.0 Cam Help
Hey guys ,
How do you think this comp cam on XER lobes (222/232 .595/.575 114 lsa) will work in a stock Lq4? I'm wanting a cam that will have a noticable lope, and will pull pretty good. The heads are stock 317 castings with a cleanup mill and the newer 918 springs. I really need some input on this project.
Old 04-24-2010, 11:06 PM
kmw0481's Avatar
Anyone.
Old 04-25-2010, 02:49 AM
Soul TKR's Avatar
Well... how extreme are you wanting to go? Do you have plans for forced induction or are you planning to stay NA?
If your looking for a fun street car, I'd go with a 228R cam or something close to that, then have your heads milled to up your compression. Should give you a really nice TQ curve for the street...
Old 04-25-2010, 08:59 AM
kmw0481's Avatar
I'm wanting a cam that is not to radical, but sound and run good also. I intend to spray 100-150hp. I probably should change cams, but I bought a this used cam and spring package a while back. I already have the 918s installed.
