pushrod preload ????? help
Old 04-24-2010, 05:29 PM
johnster's Avatar
Default pushrod preload ????? help
ok guys got me a pushrod checker and this is what i came up with
6.800+10 turns is .5 so that is 7.300 so my ? is how much preload do i need????
if i need .050 preload then i need 7.350 pushrods rite???
if i need .100 preload then 7.400 is what i need
so how much preload do i need to run so it dont sound like a bunch of ninja fightn under my hood!!!!
Old 04-24-2010, 06:22 PM
Squirts11's Avatar
Your method seems correct. What lifter are you running? <<< That will determine the proper amount of preload needed.
Old 04-24-2010, 08:34 PM
johnster's Avatar
my bad ls7 lifters, stock rockers
Old 04-24-2010, 09:10 PM
Bill'sWS6's Avatar
.050 - .080 is great. You should end up pretty quiet if you end up anywhere between 1 to 1.75 turns past zero lash to reach full tq spec.
I just went through this and we ended up a little less than 1.75 turns (about 1 2/3). It is nice and quiet with this setup.
My setup used 7.375 pushrods. I tried 7.400 and they ended up with 2.25 turns to full tq. 7.350 would have put me right on 1 full turn. I was told better to be slightly on the high side then on the low side.
Worked for me..... Good Luck!!!
Old 04-24-2010, 09:31 PM
johnster's Avatar
thanks man that helps
