camshaft suggestion?
okay guys, im looking at getting a bigger camshaft, although im not sure which one i want for sure. my goal is to get down the 1/4 as fast as possible, yet dont want a total loss of drivability....im going to be running a 3200-3600 stall and 3.73 gear through a stock 4l60e(scary i know)...so im looking for anything between a low 23x to low 24x and lift in the 59x to 61x range probably a 111 or 112 possibly with anywhere between 1 and 4 degrees of advance....im just not sure which cam (can be custom) would get me down the track the fastest with my setup and not run like total crap on the street...ls6 intake going to a fast in the future with patriot stage 2 243 heads...any suggestions on what will make usable power and a lot of it would be great, thanks for any advice in advance.....p.s. I dont want to shift past 6500 so a cam that makes a lot of power higher than that will probably not be the right cam.
LS1TECH & Trucks Sponsor
I would recommend you take a look at our torquer v.2. It provides a very broad powerband while still delivering a very noticeable power pickup. It will match up great with the stall size you are looking at.
