IS FTP 104 MM LID WITH tsp 100MAF 2MUCH considering my mods?
HEY FELLOW F-BODY OWNERS I HAVE BEEN LOOKING FOR THE BEST POSSIBLE INDUTCION KIT FOR MY 2002 WS6 ..RECENTLY I HAVE BEEN INTERESTED IN THE FTP 104 mm lid with the TSP 100 MAF...BUT I WANTED TO HEAR SOME OPINIONS. MY WORRIES R THAT I MIGHT BE BRINGING TO MUCH AIR N STILL NOT HAVE ENOUGH MODS TO HANDLE THAT KIND OF AIR....THE MODS ON MY CAR ARE MS4 WITH A LSA 111..SLP LOUDMOUTH II with TSP y-pipe ,PACESETTER HEADERS,LS2 TIMING CHAIN,PORTED LS6 OIL PUMP,SLP UNDERDRIVE PULLEY, NXT MOD WILL BE PORTING OUT MY STOCK HEADS...I WOULD REALLY APPRECIATE SOME ADVICE THANX..
If you are sticking with your LS6 intake mani and TB then it would be a bit much.... Those are going to restrict your build anyway so might as well just go 85 mm stuff. I am lookin into a 104 mm lid but then again i have a ported FAST 92/92.
You can not go too big. If the throttle body is wide open the air flow sensor is still only going to measure the air moving past it and that won't be a problem. Why not have the engine all the airflow it could ingest? I say spend the money once and have a setup you can grow into because even if it is overkill it can't cost you any power.
