LS1 vs LQ9
Old 04-26-2010, 06:40 PM
LS1T56FTW's Avatar
Default LS1 vs LQ9
H/C/I build. Which will be faster in general?
LQ9 would have LS heads obviosuly, so which would be faster? I know the LS1 is lighter, but would the LQ9 make that much more power, or no?
Thanks.
Old 04-26-2010, 06:50 PM
Squirts11's Avatar
The LQ9 obviously has a couple advantages, mainly being more displacement and strength. An iron block is usually very cheap when starting from scratch, plus its added strength is often a desired quality for those planning boost or spray.
The added weight is one of its downfalls, but those 70lbs easily be compensated for elsewhere if desired (spare tire/insulation, carpet, passenger/rear seats, etc).
Old 04-26-2010, 09:31 PM
LS1T56FTW's Avatar
Okay, well with that said, how do I know the motor that is in the car, is the one the guy says it is? I have heard there are a few different types of LQ9's, how do I know which is which? Thanks.
Old 04-26-2010, 10:23 PM
Texas_WS6's Avatar
If its was built before it was put in you will not know for sure. Does the owner have a build sheet showing what was done? Another way to see if it is worth it is to take it to the track and see for yourself what it does.
