whats the difference between LS6 and 6.0l heads? And can S3 6.0l heads..
Old 01-08-2004, 05:57 PM
SStroked 410's Avatar
Default whats the difference between LS6 and 6.0l heads? And can S3 6.0l heads..
And can S3 6.0l heads.. make more power then S3 5.7l heads with both of them having the same specs compression, valves ect. ?
Still thinking if I should go with PP S3 heads
would like to mkae over 500rwhp n/a and want to pick the right heads.
Old 01-08-2004, 06:00 PM
jrp
SN95 Director
jrp's Avatar
combustion chamber is the only difference if i recall between the ls6 and 6.0l. and yes 6.0l heads have the potential to make more power then the same configuration on some 5.7's. the ports are a better design in the ls6/6.0l.
