anyone have tsp tsunami cam?
does any one run the tsp tsunami? im considering getting this cam with the 2.5 ls6 heads. and i was just curious about drivability and low end. i saw one dynograph and it looks like it has a broad torque curve but i would like to hear from some of you guys that run this cam, pros, cons etc..
You really need to bump your compression if you're going to run any cam that size. Try to get your DCR up to around 8.5, either through a thinner head gasket or milling the heads.
Doing these things will make the car MUCH more drivable down low, otherwise it will have that "dog-like" response in the lower rpms.
Flycutting, or running pistons with valve reliefs will be needed, but that's what it will take to optimize such a large cam on the street (or on the track for that matter).
Combo, combo, combo.
Bumping compression, and thus DCR, isn't merely for low-end performance. It helps EVERYWHERE throughout the powerband, even up top. I just wanted to point out what's really needed to optimize such a large cam. These are things very few are willing to do, and thus why big cams often leave a bad taste in someone's mouth.
Bumping compression, and thus DCR, isn't merely for low-end performance. It helps EVERYWHERE throughout the powerband, even up top. I just wanted to point out what is needed to optimize such a large cam. These are things very few are willing to do, and thus why big cams often leave a bad taste in someone's mouth.
No other way around it, it's just the nature of the beast.
^^Seldom are such things done to ensure the COMBO is run optimally. When the COMBO isn't taken into consideration, it's easy to see why "my smaller cam beat my buddy's 'donkey dick' cam" is the norm around here...
It sucks, but I'm flycutting the stock pistons and milling my 243s to help compensate for the low DCR and bottom-end performance (or lack thereof) often associated with larger cams. You can have your cake and eat it too, but the process to do so isn't worth it to most people.
If TSP does anything to the heads, it'll be to sink the valves to allow for greater PTV clearance, but this won't improve the SCR/DCR, it'll just ensure that the cam will fit. Very little, if ANY, head milling will be possible with that size cam, and you most likely won't be able to run a smaller head gasket either. Running pistons with valve reliefs or flycutting are the only options to get ideal compression/DCR.
It sucks, but I'm flycutting the stock pistons and milling my 243s to help compensate for the low DCR and bottom-end performance often associated with larger cams. You can have your cake and eat it too, but the process to do so isn't worth it to most people.
scr is your static compression ratio, its the amount of compression your car has with both valves closed, your dcr is your dynamic compression ratio, or your compression with the cam in and valves moving.
You can flycut your pistons in the car with the flycutting tool. Milling the heads is easy, take it to a machine shop and have them milled.
