6.0 iron block Help
Old 01-09-2004, 09:29 AM
ROBS SS's Avatar
Default 6.0 iron block Help
When using a 6.0 iron block what do you do for the alt mounting points??? Have a motor we are putting together and getting ready to install and just noticed the mounting holes are not there for the alt assem , Sorry for the stupid ?, But as you can tell Im an LT1 Guy
Old 01-09-2004, 09:36 AM
LS1Tech Co-Founder
Nine Ball's Avatar
Most people have those drilled and tapped into the block. There should be the same places to do so.
Old 01-09-2004, 09:38 AM
Super Moderator
Reckless's Avatar
Should be a boss on the block for drilling the upper hole. Two holes will suffice to hold the alternator
Old 01-09-2004, 09:45 AM
ROBS SS's Avatar
Thanks guys, yeah I see where you can drill and tap just was not sure if there was another way, BIG Thanks again
Old 01-09-2004, 09:50 AM
LS1Tech Co-Founder
Nine Ball's Avatar
yep, I always ran my Formula with the bottom alt bolt out, it got in the way of the shortbelt mod when I was at the track.
