i just degreed my ms3 cam? help
i just degreed my ms3 cam on a 113 centerline and 113 lob sep, now i checked my math a few time and i cam of with 117* now should i retard my cam 4* or just leave it alone? ive bin told the cam may have 4* advance in it already to improve torque? any help is apprciated thanks matt
LS1Tech Premium Sponsor
What LSA did you order? On the Comp cam cards it has a line that says intake centerline...what does that line say on yours? When you say your came up with 117º, is that what you came up with for the seperation angle or the centerline on the intake?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
If you're sure it's being measured correctly then you need to retard the cam 4 degrees to get back to 113 ICL. It may be worthwhile to check the exhaust lobe as well to ensure the cam is ground correctly.
