heads and cam combo
heads and cam combo
i have a sleeved 427 stroker and wondering what heads and cam would be best i would like achieve around 600 hp all motor plan on a 250 shot on it. any advice?
I agree with the above statment or you could get a set of ETP 245cnc or TEA TFS 235CNC heads for that bad boy, if money isn't an option of course.. As far as the cam goes I would have a cam guru like Allan Futral, Patrick G, ED Curtis, etc. just to name a few to customs spec you a cam for your requirments.
I would recommend going with the TFS 235cnc heads. I have the TFS 215cnc heads on my stock bottom end 346ci LS1 and have been able to dip into the 10's on a normal basis. Again good luck with your search man.
Thats not too much head for that large an engine and they move some serious air.
The area under the curve is explosive.....over 290 CFM as early as .400 lift....its a serious piece.
PM or call should you have any questions....
-Tony
(661)705-8508
