How much gain from these mods?
Hi
I want to start putting small mods in my 97 ls1 motor
How much HP i will expect from adding these? (as begining)
-ls6 intake
-slp bellow
-ported tb
-slp maff
-ngk laser platinum spark plugs
-slp ud
-taylor 409pro race wires
-slp thermostat
-msd blaster coil packs
thanx
-ls6 intake
-slp bellow
-ported tb
-slp maff
-slp ud
-slp thermostat
thanx
ls6 intake 10-15 the tb-3-5 the ud pulley 5-8 the rest are kind of negligable though they may make the car run better...plug and wires that is..things like the maf are a waste and wont do much and may give you problems...just keep the stock maf. the coils are a tad wasteful and wont gain you much. take the money you save on the coils and maf and get a lid/exhaust or headers you will get more for your money.
Dont buy the SLP 85mm MAF. Its worthless. And its harder to tune with that on there. Second with those mods you will probably be at 315 rwhp. Somewhere around that number is realistic.
Your not going to gain anything from the MSD Blaster coils. So forget those and use that money for long tubes. If you do long tubes you will be around 330 HP.
Thanx guys
my car is 01 SS but with c5 ls1 97 motor! previous owner changed it!
so i will try to go with minimum things, instead of coils i will go with LT
I've k&n lid already! but i miss the other things
we dont have even single dynojet in our country so we usually go to DUBAI (UAE) for dyno tune but we do have diablo or hypertach things looool
thanx eveyone 4 the help and great advice's
Guys how much gain from +02 ls6 208/218 cam???
cauz i want to make my car cheater w/o anyone known its modded loool
thats why im not thinking to buy LT and off road y pipe!
are ls6 243 heads fit my car?
http://cgi.ebay.com/ebaymotors/CHEVR...Q5fAccessories
http://cgi.ebay.com/ebaymotors/ls1-l...Q5fAccessories
http://cgi.ebay.com/ebaymotors/ls2-2...Q5fAccessories
http://cgi.ebay.com/ebaymotors/LS2-S...Q5fAccessories
i thought they help my ls6 cam + ls6 intake to breathe !
you can get a mail order tune from frost,but that mite take longer for you.you could get HPtuners and tune it your self. if you can get a ls6 top end go for it.you can polish your TB your self.get a custom cam they don't cost too much more and will do what you want it to do.talk to Patrick-G or Predator-Z for cam help.
do these list
under drive pulley
ported tb
ls6 Intake
ls6 heads
Cheater V3 cam (better then ls6 and works great with stock exhaust)
cutout
tune
These you don't have to but I would
slp bellow
slp thermostat
make car lighter, there is a lot of weight that can be removed from these cars and still look stock.
under drive pulley
ported tb
ls6 Intake
ls6 heads
cutout
tune
slp bellow
slp thermostat
thanx man
do these list
under drive pulley
ported tb
ls6 Intake
ls6 heads
cutout
tune
slp bellow
slp thermostat
under drive pulley
ported tb
ls6 Intake
ls6 heads
cutout
tune
slp bellow
slp thermostat
u right there are a lot of things to b done so loss weight and gain HP even from small things!
thanx
I recently have had installed, my car already has the ls6 intake thats supposed to be better, apparently some fbodies have the ls6 engine too from factory?
slp mass air flow sensor
slp lid
slp bellow
ported tb
and I notice a good difference, its not huge but its there
it is a slight bit louder from better flow, runs smoother, idles a little better and has better throttle response
picks up on the highway a lot better
I havent gotten the cold air intake put on yet, plan on getting headers and a cam with tune soon. Have plans for full suspension with slp subframe, bolt on.
slp lid
slp bellow
ported tb
slp lid
slp bellow
ported tb
slp lid
slp bellow
ported tb
its nice if u start like im doing
goodluck with modding, keep us posted
thanx 4 sharing man
