Do the Yella Terras Clear the 98 Valve Covers?
I believe you will have to do a little grinding on the valve cover to get them to fit on a 98. This is a picture I saved after someone posted on what needed to be done to get them to work on a 98.
I don’t think a spacer will help (could be wrong) because of the design of the 98 head. The meat that you’re going to grind around the fastener would probably be duplicated on the spacer.
