What are your P/V clearance on your G5X-2 cam?
I'm trying to figure out what my P/V would be for my heads with 2.02/1.55 valves and 5.3L heads milled .010.
I had .085 clearance with a TR 230/224 .576/563 110.8LSA, so I'm wondering what I'll have with the GX5-2 cam?
Please tell me the size of your valves, cam LSA, how much your heads are milled, if you run aftermarket rockers, and the clearance you have.
Thanks guys!
Thanks guys!
I had .035" clearance with my G5X2 and 5.3L (2.02"/1.57") heads (unmilled). I cut .055" reliefs in the pistons to get me to .090". I just replaced the 5.3's with a set of PP LS6/LQ9 (59cc) Stg2 heads and I had about .154" ptv clearance (but the pistons were already cut). So if you do the math and subtract the .055" that I cut from my pistons, I would have had .100" ptv with the Patriot heads and the G5X2 without cutting reliefs. that is what makes these heads so attractive to the big cam guys that don't want to mess with cutting reliefs.
Since you have the G5X2 I can tell you how to measure PTV without using the clay method:
#1 Remove the springs from the intake and exhaust valves on the #1 cylinder.
#2 Bring the #1 piston to exact TDC.
#3 Install this head using an old head gasket and install a few bolts and snug them up, no need to torque them.
#4 Setup a dial caliper to measure on the tip of the valve stem. Hold the valve up against the seat and zero the caliper.
#5 Push the valve down until it touches the top of the piston. Read the caliper and record how far the valve dropped.
EXAMPLE
G5X2 has an intake valve lift of .120" when the piston is at TDC (direct from Lou).
Measured valve drop = .220"
Minus the .120" lift @ TDC
Equals .100" PTV Clearance
EXAMPLE
EXAMPLE
EXAMPLE
Originally Posted by gomer
I'm missing something after reading the post above... How can you have two sets of heads.. both at stock deck height (you said the 5.3's were unmilled) and not have the same P/V clearance? Or atleast somewhere close. There is a .065 difference between your unmilled 5.3 numbers and your unmilled LS6 style numbers.
Another thing is with different sized valves. A larger valve will obviously give you less clearance. He may also have smaller valves in the LQ9 head.
